Test LB+PPO0563
PPC LB+PPO0563
"PodRW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR PosRR"
Cycle=Rfe PosRR DpAddrdW PosWR PosRR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR PosRR
0:r2=z; 0:r4=x;
1:r2=x; 1:r6=y; 1:r10=z;
 P0           | P1            ;
 lwz r1,0(r2) | lwz r1,0(r2)  ;
 xor r3,r1,r1 | lwz r3,0(r2)  ;
 addi r3,r3,1 | xor r4,r3,r3  ;
 stw r3,0(r4) | li r5,1       ;
              | stwx r5,r4,r6 ;
              | lwz r7,0(r6)  ;
              | lwz r8,0(r6)  ;
              | li r9,1       ;
              | stw r9,0(r10) ;
exists
(0:r1=1 /\ 1:r1=1)
