PPC LB+PPO0538 "PodRW Rfe DpDatadW Rfe DpAddrdR DpAddrdW PosWR DpAddrdR PosRR" Cycle=Rfe DpAddrdR DpAddrdW PosWR DpAddrdR PosRR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdR DpAddrdW PosWR DpAddrdR PosRR { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r8=z; 1:r12=a; 1:r15=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | xor r6,r4,r4 ; | li r7,1 ; | stwx r7,r6,r8 ; | lwz r9,0(r8) ; | xor r10,r9,r9 ; | lwzx r11,r10,r12 ; | lwz r13,0(r12) ; | li r14,1 ; | stw r14,0(r15) ; exists (0:r1=1 /\ 1:r1=1)
