Test LB+PPO0530
PPC LB+PPO0530
"PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWR PosRR PosRW"
Cycle=Rfe PosRR DpDatadW PosWR PosRR PosRW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWR PosRR PosRW
0:r2=z; 0:r4=x;
1:r2=x; 1:r5=y; 1:r10=z;
 P0           | P1            ;
 lwz r1,0(r2) | lwz r1,0(r2)  ;
 xor r3,r1,r1 | lwz r3,0(r2)  ;
 addi r3,r3,1 | xor r4,r3,r3  ;
 stw r3,0(r4) | addi r4,r4,1  ;
              | stw r4,0(r5)  ;
              | lwz r6,0(r5)  ;
              | lwz r7,0(r5)  ;
              | li r8,2       ;
              | stw r8,0(r5)  ;
              | li r9,1       ;
              | stw r9,0(r10) ;
exists
(y=2 /\ 0:r1=1 /\ 1:r1=1)
