Test LB+PPO0494
PPC LB+PPO0494
"PodRW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR PosRW PosWR"
Cycle=Rfe DpAddrdW PosWR PosRR PosRW PosWR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdW DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR PosRW PosWR
0:r2=z; 0:r4=x;
1:r2=x; 1:r5=y; 1:r11=z;
 P0           | P1             ;
 lwz r1,0(r2) | lwz r1,0(r2)   ;
 xor r3,r1,r1 | xor r3,r1,r1   ;
 addi r3,r3,1 | li r4,1        ;
 stw r3,0(r4) | stwx r4,r3,r5  ;
              | lwz r6,0(r5)   ;
              | lwz r7,0(r5)   ;
              | li r8,2        ;
              | stw r8,0(r5)   ;
              | lwz r9,0(r5)   ;
              | li r10,1       ;
              | stw r10,0(r11) ;
exists
(y=2 /\ 0:r1=1 /\ 1:r1=1)
