PPC LB+PPO0488 "PodRW Rfe DpDatadW Rfe DpCtrldW PosWR DpAddrdR PosRW PosWR" Cycle=Rfe DpDatadW Rfe DpCtrldW PosWR DpAddrdR PosRW PosWR PodRW Relax= Safe=Rfe PosWR PosRW Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpCtrldW PosWR DpAddrdR PosRW PosWR { 0:r2=a; 0:r4=x; 1:r2=x; 1:r4=y; 1:r8=z; 1:r12=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | cmpw r1,r1 ; addi r3,r3,1 | beq LC00 ; stw r3,0(r4) | LC00: ; | li r3,1 ; | stw r3,0(r4) ; | lwz r5,0(r4) ; | xor r6,r5,r5 ; | lwzx r7,r6,r8 ; | li r9,1 ; | stw r9,0(r8) ; | lwz r10,0(r8) ; | li r11,1 ; | stw r11,0(r12) ; exists (0:r1=1 /\ 1:r1=1)
