PPC LB+PPO0427 "PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR DpDatadW PosWR" Cycle=Rfe PosRR PosRW PosWR DpDatadW PosWR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR DpDatadW PosWR { 0:r2=z; 0:r4=x; 1:r2=x; 1:r7=y; 1:r10=z; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | li r4,2 ; stw r3,0(r4) | stw r4,0(r2) ; | lwz r5,0(r2) ; | xor r6,r5,r5 ; | addi r6,r6,1 ; | stw r6,0(r7) ; | lwz r8,0(r7) ; | li r9,1 ; | stw r9,0(r10) ; exists (x=2 /\ 0:r1=1 /\ 1:r1=1)
