PPC LB+PPO0426 "PodRW Rfe DpDatadW Rfe DpAddrdR PosRW PosWR DpDatadW PosWR" Cycle=Rfe DpAddrdR PosRW PosWR DpDatadW PosWR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW Pod*W DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdR PosRW PosWR DpDatadW PosWR { 0:r2=a; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; 1:r12=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | li r6,1 ; | stw r6,0(r5) ; | lwz r7,0(r5) ; | xor r8,r7,r7 ; | addi r8,r8,1 ; | stw r8,0(r9) ; | lwz r10,0(r9) ; | li r11,1 ; | stw r11,0(r12) ; exists (0:r1=1 /\ 1:r1=1)
