PPC LB+PPO0409 "PodRW Rfe DpDatadW Rfe DpAddrdW PosWR DpAddrdR DpDatadW PosWR" Cycle=Rfe DpAddrdW PosWR DpAddrdR DpDatadW PosWR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdW PosWR DpAddrdR DpDatadW PosWR { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; 1:r11=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | li r4,1 ; stw r3,0(r4) | stwx r4,r3,r5 ; | lwz r6,0(r5) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | xor r10,r8,r8 ; | addi r10,r10,1 ; | stw r10,0(r11) ; | lwz r12,0(r11) ; | li r13,1 ; | stw r13,0(r14) ; exists (0:r1=1 /\ 1:r1=1)
