PPC LB+PPO0359 "PodWW Rfe DpDatadW Rfe DpAddrdR PosRR DpAddrdR DpCtrldW PosWW" Cycle=Rfe DpAddrdR PosRR DpAddrdR DpCtrldW PosWW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpAddrdR PosRR DpAddrdR DpCtrldW PosWW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; 1:r11=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | cmpw r8,r8 ; | beq LC00 ; | LC00: ; | li r10,1 ; | stw r10,0(r11) ; | li r12,2 ; | stw r12,0(r11) ; | li r13,1 ; | stw r13,0(r14) ; exists (a=2 /\ 0:r1=1 /\ 1:r1=1)
