PPC LB+PPO0352 "PodWW Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpDatadW PosWW" Cycle=Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpDatadW PosWW PodWW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpDatadW PosWW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r4=y; 1:r8=z; 1:r11=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | cmpw r1,r1 ; addi r3,r3,1 | beq LC00 ; stw r3,0(r4) | LC00: ; | li r3,1 ; | stw r3,0(r4) ; | lwz r5,0(r4) ; | lwz r6,0(r4) ; | xor r7,r6,r6 ; | addi r7,r7,1 ; | stw r7,0(r8) ; | li r9,2 ; | stw r9,0(r8) ; | li r10,1 ; | stw r10,0(r11) ; exists (z=2 /\ 0:r1=1 /\ 1:r1=1)
