Test LB+PPO0346
PPC LB+PPO0346
"PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpDatadW PosWW"
Cycle=Rfe PosRR PosRW PosWR DpDatadW PosWW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosWW PosWR PosRW PosRR Pod*W DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpDatadW PosWW
0:r2=z; 0:r4=x;
1:r2=x; 1:r7=y; 1:r10=z;
 P0           | P1            ;
 lwz r1,0(r2) | lwz r1,0(r2)  ;
 xor r3,r1,r1 | lwz r3,0(r2)  ;
 addi r3,r3,1 | li r4,2       ;
 stw r3,0(r4) | stw r4,0(r2)  ;
              | lwz r5,0(r2)  ;
              | xor r6,r5,r5  ;
              | addi r6,r6,1  ;
              | stw r6,0(r7)  ;
              | li r8,2       ;
              | stw r8,0(r7)  ;
              | li r9,1       ;
              | stw r9,0(r10) ;
exists
(x=2 /\ y=2 /\ 0:r1=1 /\ 1:r1=1)
