PPC LB+PPO0323 "PodWW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR DpAddrdW PosWW" Cycle=Rfe DpAddrdW PosWR PosRR DpAddrdW PosWW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR DpAddrdW PosWW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r5=y; 1:r10=z; 1:r13=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | li r4,1 ; stw r3,0(r4) | stwx r4,r3,r5 ; | lwz r6,0(r5) ; | lwz r7,0(r5) ; | xor r8,r7,r7 ; | li r9,1 ; | stwx r9,r8,r10 ; | li r11,2 ; | stw r11,0(r10) ; | li r12,1 ; | stw r12,0(r13) ; exists (z=2 /\ 0:r1=1 /\ 1:r1=1)
