PPC LB+PPO0308 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR DpAddrdW PosWW" Cycle=Rfe PosRR DpAddrdW PosWR DpAddrdW PosWW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR DpAddrdW PosWW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r6=y; 1:r10=z; 1:r13=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | li r5,1 ; | stwx r5,r4,r6 ; | lwz r7,0(r6) ; | xor r8,r7,r7 ; | li r9,1 ; | stwx r9,r8,r10 ; | li r11,2 ; | stw r11,0(r10) ; | li r12,1 ; | stw r12,0(r13) ; exists (z=2 /\ 0:r1=1 /\ 1:r1=1)
