Test LB+PPO0284
PPC LB+PPO0284
"PodWW Rfe DpDatadW Rfe DpAddrdR PosRR DpAddrdR PosRR DpCtrldW"
Cycle=Rfe DpAddrdR PosRR DpAddrdR PosRR DpCtrldW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosRR Pod*W DpAddrdR DpDatadW DpCtrldW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe DpAddrdR PosRR DpAddrdR PosRR DpCtrldW
0:r2=b; 0:r4=x;
1:r2=x; 1:r5=y; 1:r9=z; 1:r12=a; 1:r14=b;
 P0           | P1             ;
 lwz r1,0(r2) | lwz r1,0(r2)   ;
 xor r3,r1,r1 | xor r3,r1,r1   ;
 addi r3,r3,1 | lwzx r4,r3,r5  ;
 stw r3,0(r4) | lwz r6,0(r5)   ;
              | xor r7,r6,r6   ;
              | lwzx r8,r7,r9  ;
              | lwz r10,0(r9)  ;
              | cmpw r10,r10   ;
              | beq  LC00      ;
              | LC00:          ;
              | li r11,1       ;
              | stw r11,0(r12) ;
              | li r13,1       ;
              | stw r13,0(r14) ;
exists
(0:r1=1 /\ 1:r1=1)
