PPC LB+PPO0273 "PodWW Rfe DpDatadW Rfe PosRR DpCtrldW PosWW PosWR DpCtrldW" Cycle=Rfe PosRR DpCtrldW PosWW PosWR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpCtrldW PosWW PosWR DpCtrldW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; 1:r11=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | cmpw r3,r3 ; stw r3,0(r4) | beq LC00 ; | LC00: ; | li r4,1 ; | stw r4,0(r5) ; | li r6,2 ; | stw r6,0(r5) ; | lwz r7,0(r5) ; | cmpw r7,r7 ; | beq LC01 ; | LC01: ; | li r8,1 ; | stw r8,0(r9) ; | li r10,1 ; | stw r10,0(r11) ; exists (y=2 /\ 0:r1=1 /\ 1:r1=1)
