PPC LB+PPO0251 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdR DpDatadW PosWR DpCtrldW" Cycle=Rfe PosRR DpAddrdR DpDatadW PosWR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdR DpDatadW PosWR DpCtrldW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r6=y; 1:r8=z; 1:r11=a; 1:r13=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | lwzx r5,r4,r6 ; | xor r7,r5,r5 ; | addi r7,r7,1 ; | stw r7,0(r8) ; | lwz r9,0(r8) ; | cmpw r9,r9 ; | beq LC00 ; | LC00: ; | li r10,1 ; | stw r10,0(r11) ; | li r12,1 ; | stw r12,0(r13) ; exists (0:r1=1 /\ 1:r1=1)
