PPC LB+PPO0248 "PodWW Rfe DpDatadW Rfe DpAddrdR PosRR DpAddrdW PosWR DpCtrldW" Cycle=Rfe DpAddrdR PosRR DpAddrdW PosWR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpAddrdR PosRR DpAddrdW PosWR DpCtrldW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; 1:r12=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | xor r7,r6,r6 ; | li r8,1 ; | stwx r8,r7,r9 ; | lwz r10,0(r9) ; | cmpw r10,r10 ; | beq LC00 ; | LC00: ; | li r11,1 ; | stw r11,0(r12) ; | li r13,1 ; | stw r13,0(r14) ; exists (0:r1=1 /\ 1:r1=1)
