PPC LB+PPO0247 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR DpCtrldW" Cycle=Rfe PosRR DpAddrdW PosWR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR DpCtrldW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r6=y; 1:r9=z; 1:r11=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | li r5,1 ; | stwx r5,r4,r6 ; | lwz r7,0(r6) ; | cmpw r7,r7 ; | beq LC00 ; | LC00: ; | li r8,1 ; | stw r8,0(r9) ; | li r10,1 ; | stw r10,0(r11) ; exists (0:r1=1 /\ 1:r1=1)
