PPC LB+PPO0240 "PodWW Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpAddrdR DpCtrldW" Cycle=Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpAddrdR DpCtrldW PodWW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpAddrdR DpCtrldW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r4=y; 1:r9=z; 1:r11=a; 1:r13=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | cmpw r1,r1 ; addi r3,r3,1 | beq LC00 ; stw r3,0(r4) | LC00: ; | li r3,1 ; | stw r3,0(r4) ; | lwz r5,0(r4) ; | lwz r6,0(r4) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | cmpw r8,r8 ; | beq LC01 ; | LC01: ; | li r10,1 ; | stw r10,0(r11) ; | li r12,1 ; | stw r12,0(r13) ; exists (0:r1=1 /\ 1:r1=1)
