PPC LB+PPO0238 "PodWW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR DpAddrdR DpCtrldW" Cycle=Rfe DpAddrdW PosWR PosRR DpAddrdR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR DpAddrdR DpCtrldW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r10=z; 1:r12=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | li r4,1 ; stw r3,0(r4) | stwx r4,r3,r5 ; | lwz r6,0(r5) ; | lwz r7,0(r5) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | cmpw r9,r9 ; | beq LC00 ; | LC00: ; | li r11,1 ; | stw r11,0(r12) ; | li r13,1 ; | stw r13,0(r14) ; exists (0:r1=1 /\ 1:r1=1)
