PPC LB+PPO0237 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdR PosRR DpAddrdR DpCtrldW" Cycle=Rfe PosRR DpAddrdR PosRR DpAddrdR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdR PosRR DpAddrdR DpCtrldW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r6=y; 1:r10=z; 1:r12=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | lwzx r5,r4,r6 ; | lwz r7,0(r6) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | cmpw r9,r9 ; | beq LC00 ; | LC00: ; | li r11,1 ; | stw r11,0(r12) ; | li r13,1 ; | stw r13,0(r14) ; exists (0:r1=1 /\ 1:r1=1)
