PPC LB+PPO0234 "PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR DpCtrldW" Cycle=Rfe PosRR PosRW PosWR DpAddrdR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR DpCtrldW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r8=y; 1:r10=z; 1:r12=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | li r4,2 ; stw r3,0(r4) | stw r4,0(r2) ; | lwz r5,0(r2) ; | xor r6,r5,r5 ; | lwzx r7,r6,r8 ; | cmpw r7,r7 ; | beq LC00 ; | LC00: ; | li r9,1 ; | stw r9,0(r10) ; | li r11,1 ; | stw r11,0(r12) ; exists (x=2 /\ 0:r1=1 /\ 1:r1=1)
