PPC LB+PPO0197 "PodWW Rfe DpDatadW Rfe DpAddrdR PosRR PosRW PosWR DpDatadW" Cycle=Rfe DpAddrdR PosRR PosRW PosWR DpDatadW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpAddrdR PosRR PosRW PosWR DpDatadW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r5=y; 1:r10=z; 1:r12=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | li r7,1 ; | stw r7,0(r5) ; | lwz r8,0(r5) ; | xor r9,r8,r8 ; | addi r9,r9,1 ; | stw r9,0(r10) ; | li r11,1 ; | stw r11,0(r12) ; exists (0:r1=1 /\ 1:r1=1)
