PPC LB+PPO0187 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWW PosWR DpDatadW" Cycle=Rfe PosRR DpAddrdW PosWW PosWR DpDatadW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWW PosWR DpDatadW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r6=y; 1:r10=z; 1:r12=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | li r5,1 ; | stwx r5,r4,r6 ; | li r7,2 ; | stw r7,0(r6) ; | lwz r8,0(r6) ; | xor r9,r8,r8 ; | addi r9,r9,1 ; | stw r9,0(r10) ; | li r11,1 ; | stw r11,0(r12) ; exists (y=2 /\ 0:r1=1 /\ 1:r1=1)
