PPC LB+PPO0138 "PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR DpAddrdW" Cycle=Rfe PosRR PosRW PosWR PosRR DpAddrdW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdW DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR DpAddrdW { 0:r2=z; 0:r4=x; 1:r2=x; 1:r9=y; 1:r11=z; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | li r4,2 ; stw r3,0(r4) | stw r4,0(r2) ; | lwz r5,0(r2) ; | lwz r6,0(r2) ; | xor r7,r6,r6 ; | li r8,1 ; | stwx r8,r7,r9 ; | li r10,1 ; | stw r10,0(r11) ; exists (x=2 /\ 0:r1=1 /\ 1:r1=1)
