PPC LB+PPO0136 "PodWW Rfe DpDatadW Rfe DpCtrldW PosWW PosWR PosRR DpAddrdW" Cycle=Rfe DpDatadW Rfe DpCtrldW PosWW PosWR PosRR DpAddrdW PodWW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpCtrldW PosWW PosWR PosRR DpAddrdW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r4=y; 1:r10=z; 1:r12=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | cmpw r1,r1 ; addi r3,r3,1 | beq LC00 ; stw r3,0(r4) | LC00: ; | li r3,1 ; | stw r3,0(r4) ; | li r5,2 ; | stw r5,0(r4) ; | lwz r6,0(r4) ; | lwz r7,0(r4) ; | xor r8,r7,r7 ; | li r9,1 ; | stwx r9,r8,r10 ; | li r11,1 ; | stw r11,0(r12) ; exists (y=2 /\ 0:r1=1 /\ 1:r1=1)
