PPC LB+PPO0127 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdW" Cycle=Rfe PosRR DpAddrdW PosWR PosRR DpAddrdW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdW { 0:r2=a; 0:r4=x; 1:r2=x; 1:r6=y; 1:r11=z; 1:r13=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | li r5,1 ; | stwx r5,r4,r6 ; | lwz r7,0(r6) ; | lwz r8,0(r6) ; | xor r9,r8,r8 ; | li r10,1 ; | stwx r10,r9,r11 ; | li r12,1 ; | stw r12,0(r13) ; exists (0:r1=1 /\ 1:r1=1)
