PPC LB+PPO0073 "PodWW Rfe DpDatadW Rfe DpAddrdR PosRW PosWR DpAddrdR DpAddrdW" Cycle=Rfe DpAddrdR PosRW PosWR DpAddrdR DpAddrdW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpAddrdR PosRW PosWR DpAddrdR DpAddrdW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r10=z; 1:r13=a; 1:r15=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | li r6,1 ; | stw r6,0(r5) ; | lwz r7,0(r5) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | xor r11,r9,r9 ; | li r12,1 ; | stwx r12,r11,r13 ; | li r14,1 ; | stw r14,0(r15) ; exists (0:r1=1 /\ 1:r1=1)
