PPC LB+PPO0071 "PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpAddrdR DpAddrdW" Cycle=Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpAddrdR DpAddrdW PodWW Relax= Safe=Rfe PosWW PosWR Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpAddrdR DpAddrdW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r4=y; 1:r9=z; 1:r12=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | addi r3,r3,1 ; stw r3,0(r4) | stw r3,0(r4) ; | li r5,2 ; | stw r5,0(r4) ; | lwz r6,0(r4) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | xor r10,r8,r8 ; | li r11,1 ; | stwx r11,r10,r12 ; | li r13,1 ; | stw r13,0(r14) ; exists (y=2 /\ 0:r1=1 /\ 1:r1=1)
