PPC LB+PPO0063 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR DpAddrdR DpAddrdW" Cycle=Rfe PosRR DpAddrdW PosWR DpAddrdR DpAddrdW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdW PosWR DpAddrdR DpAddrdW { 0:r2=b; 0:r4=x; 1:r2=x; 1:r6=y; 1:r10=z; 1:r13=a; 1:r15=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | xor r4,r3,r3 ; stw r3,0(r4) | li r5,1 ; | stwx r5,r4,r6 ; | lwz r7,0(r6) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | xor r11,r9,r9 ; | li r12,1 ; | stwx r12,r11,r13 ; | li r14,1 ; | stw r14,0(r15) ; exists (0:r1=1 /\ 1:r1=1)
