Test LB+PPO0058
PPC LB+PPO0058
"PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR DpAddrdR"
Cycle=Rfe PosRR PosRW PosWR PosRR DpAddrdR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR DpAddrdR
0:r2=z; 0:r4=x;
1:r2=x; 1:r9=y; 1:r11=z;
 P0           | P1             ;
 lwz r1,0(r2) | lwz r1,0(r2)   ;
 xor r3,r1,r1 | lwz r3,0(r2)   ;
 addi r3,r3,1 | li r4,2        ;
 stw r3,0(r4) | stw r4,0(r2)   ;
              | lwz r5,0(r2)   ;
              | lwz r6,0(r2)   ;
              | xor r7,r6,r6   ;
              | lwzx r8,r7,r9  ;
              | li r10,1       ;
              | stw r10,0(r11) ;
exists
(x=2 /\ 0:r1=1 /\ 1:r1=1)
