PPC LB+PPO0054 "PodRW Rfe DpDatadW Rfe DpAddrdW PosWW PosWR PosRR DpAddrdR" Cycle=Rfe DpAddrdW PosWW PosWR PosRR DpAddrdR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdW PosWW PosWR PosRR DpAddrdR { 0:r2=a; 0:r4=x; 1:r2=x; 1:r5=y; 1:r11=z; 1:r13=a; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | li r4,1 ; stw r3,0(r4) | stwx r4,r3,r5 ; | li r6,2 ; | stw r6,0(r5) ; | lwz r7,0(r5) ; | lwz r8,0(r5) ; | xor r9,r8,r8 ; | lwzx r10,r9,r11 ; | li r12,1 ; | stw r12,0(r13) ; exists (y=2 /\ 0:r1=1 /\ 1:r1=1)
