PPC LB+PPO0052 "PodRW Rfe DpDatadW Rfe DpAddrdR DpCtrldW PosWR PosRR DpAddrdR" Cycle=Rfe DpAddrdR DpCtrldW PosWR PosRR DpAddrdR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdR DpCtrldW PosWR PosRR DpAddrdR { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r7=z; 1:r12=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | cmpw r4,r4 ; | beq LC00 ; | LC00: ; | li r6,1 ; | stw r6,0(r7) ; | lwz r8,0(r7) ; | lwz r9,0(r7) ; | xor r10,r9,r9 ; | lwzx r11,r10,r12 ; | li r13,1 ; | stw r13,0(r14) ; exists (0:r1=1 /\ 1:r1=1)
