Test LB+PPO0045
PPC LB+PPO0045
"PodRW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR DpAddrdR"
Cycle=Rfe DpAddrdW PosWR PosRR DpAddrdR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpAddrdW PosWR PosRR DpAddrdR
0:r2=a; 0:r4=x;
1:r2=x; 1:r5=y; 1:r10=z; 1:r12=a;
 P0           | P1             ;
 lwz r1,0(r2) | lwz r1,0(r2)   ;
 xor r3,r1,r1 | xor r3,r1,r1   ;
 addi r3,r3,1 | li r4,1        ;
 stw r3,0(r4) | stwx r4,r3,r5  ;
              | lwz r6,0(r5)   ;
              | lwz r7,0(r5)   ;
              | xor r8,r7,r7   ;
              | lwzx r9,r8,r10 ;
              | li r11,1       ;
              | stw r11,0(r12) ;
exists
(0:r1=1 /\ 1:r1=1)
