Test LB+PPO0027
PPC LB+PPO0027
"PodRW Rfe DpDatadW Rfe PosRR DpAddrdW PosWW PosWR DpAddrdR"
Cycle=Rfe PosRR DpAddrdW PosWW PosWR DpAddrdR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdW DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR DpAddrdW PosWW PosWR DpAddrdR
0:r2=a; 0:r4=x;
1:r2=x; 1:r6=y; 1:r11=z; 1:r13=a;
 P0           | P1              ;
 lwz r1,0(r2) | lwz r1,0(r2)    ;
 xor r3,r1,r1 | lwz r3,0(r2)    ;
 addi r3,r3,1 | xor r4,r3,r3    ;
 stw r3,0(r4) | li r5,1         ;
              | stwx r5,r4,r6   ;
              | li r7,2         ;
              | stw r7,0(r6)    ;
              | lwz r8,0(r6)    ;
              | xor r9,r8,r8    ;
              | lwzx r10,r9,r11 ;
              | li r12,1        ;
              | stw r12,0(r13)  ;
exists
(y=2 /\ 0:r1=1 /\ 1:r1=1)
