PPC LB+PPO0006 "PodRW Rfe DpDatadW Rfe DpCtrldW PosWR DpAddrdW PosWR DpAddrdR" Cycle=Rfe DpDatadW Rfe DpCtrldW PosWR DpAddrdW PosWR DpAddrdR PodRW Relax= Safe=Rfe PosWR Pod*W DpAddrdW DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpCtrldW PosWR DpAddrdW PosWR DpAddrdR { 0:r2=b; 0:r4=x; 1:r2=x; 1:r4=y; 1:r8=z; 1:r12=a; 1:r14=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | cmpw r1,r1 ; addi r3,r3,1 | beq LC00 ; stw r3,0(r4) | LC00: ; | li r3,1 ; | stw r3,0(r4) ; | lwz r5,0(r4) ; | xor r6,r5,r5 ; | li r7,1 ; | stwx r7,r6,r8 ; | lwz r9,0(r8) ; | xor r10,r9,r9 ; | lwzx r11,r10,r12 ; | li r13,1 ; | stw r13,0(r14) ; exists (0:r1=1 /\ 1:r1=1)
