PPC LB+PPO0004 "PodRW Rfe DpDatadW Rfe DpAddrdW PosWR DpAddrdW PosWR DpAddrdR" Cycle=Rfe DpAddrdW PosWR DpAddrdW PosWR DpAddrdR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR Pod*W DpAddrdW DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdW PosWR DpAddrdW PosWR DpAddrdR { 0:r2=b; 0:r4=x; 1:r2=x; 1:r5=y; 1:r9=z; 1:r13=a; 1:r15=b; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | li r4,1 ; stw r3,0(r4) | stwx r4,r3,r5 ; | lwz r6,0(r5) ; | xor r7,r6,r6 ; | li r8,1 ; | stwx r8,r7,r9 ; | lwz r10,0(r9) ; | xor r11,r10,r10 ; | lwzx r12,r11,r13 ; | li r14,1 ; | stw r14,0(r15) ; exists (0:r1=1 /\ 1:r1=1)
