PPC CO-LB+fri+pos-fri "Fri Rfe PosRR Fri Rfe" (* Revealed a T2 model bug *) Cycle=Rfe Fri Rfe PosRR Fri Prefetch=0:x=F,0:x=W,1:x=F,1:x=W Com=Rf Rf Orig=Fri Rfe PosRR Fri Rfe { 0:r2=x; 1:r2=x; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; li r3,1 | lwz r3,0(r2) ; stw r3,0(r2) | li r4,2 ; | stw r4,0(r2) ; exists (not (x=2 /\ 0:r1=0 /\ (1:r3=1 /\ (1:r1=1 \/ 1:r1=0) \/ 1:r3=0 /\ 1:r1=0) \/ x=1 /\ 1:r3=0 /\ 1:r1=0 /\ (0:r1=2 \/ 0:r1=0)))
