ARM LB+PPO0036 "PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR" Cycle=Rfe PosRR PosRW PosWR DpAddrdR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR { %z0=z; %x0=x; %x1=x; %y1=y; %z1=z; } P0 | P1 ; LDR R0,[%z0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | MOV R2,#2 ; STR R1,[%x0] | STR R2,[%x1] ; | LDR R3,[%x1] ; | EOR R4,R3,R3 ; | LDR R5,[R4,%y1] ; | MOV R6,#1 ; | STR R6,[%z1] ; Observed 0:R0=1; 1:R0=1; x=2;
