Executions for behaviour:
"1:R0=1 ; 1:R1=0 ; x=1"
ARM DETOUR1190 "DMBdWW Rfe PosRR Fri PodWW Wse" Cycle=Rfe PosRR Fri PodWW Wse DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe PosRR Fri PodWW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | LDR R1,[%y1] ; DMB | MOV R2,#2 ; MOV R1,#1 | STR R2,[%y1] ; STR R1,[%y0] | MOV R3,#1 ; | STR R3,[%x1] ; Observed 1:R0=1; 1:R1=0; x=1;
