Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; y=2"
ARM LB0027 "DpDatadW Rfe PosRW PosWR DpDatadW Rfe" Cycle=Rfe PosRW PosWR DpDatadW Rfe DpDatadW Relax=[Rfe,DpDatadW,Rfe] Safe=PosWR PosRW DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRW PosWR DpDatadW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | MOV R1,#2 ; ADD R1,R1,#1 | STR R1,[%y1] ; STR R1,[%y0] | LDR R2,[%y1] ; | EOR R3,R2,R2 ; | ADD R3,R3,#1 ; | STR R3,[%x1] ; Observed 0:R0=1; 1:R0=1; y=2;
