Executions for behaviour:
"0:R1=1 ; 0:R2=2 ; 2:R0=1 ; 2:R2=1 ; x=1"
"0:R1=3 ; 0:R2=2 ; 2:R0=0 ; 2:R2=2 ; x=3"
ARM WWC+LBs "From DetourW PosRR DpCtrldW Rfe DpDatadW Wse, seen state features LB or WWC" (* Observation on DETOUR0443 probably due to uniproc violation *) Cycle=Rfe DpDatadW Wse DetourW PosRR DpCtrldW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DetourW PosRR DpCtrldW Rfe DpDatadW Wse { %x0=x; %y0=y; %x1=x; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | MOV R0,#3 | LDR R0,[%y2] ; STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ; LDR R1,[%x0] | | ADD R1,R1,#1 ; LDR R2,[%x0] | | STR R1,[%x2] ; CMP R2,R2 | | DMB ; BNE LC00 | | LDR R2,[%x2] ; LC00: | | ; MOV R3,#1 | | ; STR R3,[%y0] | | ; Observed 0:R1=1; 0:R2=2; 2:R0=1; 2:R2=1; x=1; and 0:R1=3; 0:R2=2; 2:R0=0; 2:R2=2; x=3;
