Test Z6.0+rfiar-datarna+addr+dmb
Executions for behaviour: "0:R0=0 ; 0:R1=1 ; 1:R0=1 ; 2:R1=0 ; ok=1 ; x=1 ; z=2"
ARM Z6.0+rfiar-datarna+addr+dmb
"RfiAR DpDatadWRNa Rfe DpAddrdW Wse DMBdWR FreNaA"
Cycle=RfiAR DpDatadWRNa Rfe DpAddrdW Wse DMBdWR FreNaA
Prefetch=0:x=F,0:y=W,1:y=F,1:z=W,2:z=F,2:x=T
Com=Rf Ws Fr
Orig=RfiAR DpDatadWRNa Rfe DpAddrdW Wse DMBdWR FreNaA
{ ok=1;
%x0=x; %y0=y; %ok0=ok;
%y1=y; %z1=z;
%z2=z; %x2=x;
 P0                  | P1              | P2           ;
 MOV %T3,#1          | LDR R0,[%y1]    | MOV R0,#2    ;
 LDREX R0,[%x0]      | EOR R1,R0,R0    | STR R0,[%z2] ;
 STREX %T2,%T3,[%x0] | MOV R2,#1       | DMB          ;
 CMP %T2,#0          | STR R2,[R1,%z1] | LDR R1,[%x2] ;
 BNE Fail0           |                 |              ;
 LDREX R1,[%x0]      |                 |              ;
 EOR R2,R1,R1        |                 |              ;
 ADD R2,R2,#1        |                 |              ;
 STR R2,[%y0]        |                 |              ;
 B Exit0             |                 |              ;
 Fail0:              |                 |              ;
 MOV R3,#0           |                 |              ;
 STR R3,[%ok0]       |                 |              ;
 Exit0:              |                 |              ;
Observed
    0:R0=0; 0:R1=1; 1:R0=1; 2:R1=0; ok=1; x=1; z=2;
