Executions for behaviour:
"0:R0=1 ; 1:R0=2 ; 1:R2=0 ; 2:R0=1 ; ok=1 ; x=2 ; y=1"
ARM WWC+addrra+dmb+A "RfeAR DpAddrdWRA RfeANa DMBdRW WseNaA" Cycle=RfeANa DMBdRW WseNaA RfeAR DpAddrdWRA Prefetch=1:x=F,1:y=W,2:y=F,2:x=W Com=Rf Rf Ws Orig=RfeAR DpAddrdWRA RfeANa DMBdRW WseNaA { ok=1; %x0=x; %ok0=ok; %x1=x; %y1=y; %ok1=ok; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV %T3,#2 | LDREX R0,[%x1] | LDR R0,[%y2] ; LDREX R0,[%x0] | EOR R1,R0,R0 | DMB ; STREX %T2,%T3,[%x0] | ADD %T1,R1,%y1 | MOV R1,#1 ; CMP %T2,#0 | MOV %T3,#1 | STR R1,[%x2] ; BNE Fail0 | LDREX R2,[%T1] | ; B Exit0 | STREX %T2,%T3,[%T1] | ; Fail0: | CMP %T2,#0 | ; MOV R1,#0 | BNE Fail1 | ; STR R1,[%ok0] | B Exit1 | ; Exit0: | Fail1: | ; | MOV R3,#0 | ; | STR R3,[%ok1] | ; | Exit1: | ; Observed 0:R0=1; 1:R0=2; 1:R2=0; 2:R0=1; ok=1; x=2; y=1;
