Executions for behaviour:
"1:R0=1 ; 2:R0=1 ; 2:R2=0 ; ok=1 ; x=1"
ARM WRC+dataana+addr "RfeNaA DpDatadWANa Rfe DpAddrdR Fre" Cycle=Rfe DpAddrdR Fre RfeNaA DpDatadWANa Prefetch=1:x=F,1:y=W,2:y=F,2:x=T Com=Rf Rf Fr Orig=RfeNaA DpDatadWANa Rfe DpAddrdR Fre { ok=1; %x0=x; %x1=x; %y1=y; %ok1=ok; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | LDREX R0,[%x1] | LDR R0,[%y2] ; STR R0,[%x0] | STREX %T2,R0,[%x1] | EOR R1,R0,R0 ; | CMP %T2,#0 | LDR R2,[R1,%x2] ; | BNE Fail1 | ; | EOR R1,R0,R0 | ; | ADD R1,R1,#1 | ; | STR R1,[%y1] | ; | B Exit1 | ; | Fail1: | ; | MOV R2,#0 | ; | STR R2,[%ok1] | ; | Exit1: | ; Observed 1:R0=1; 2:R0=1; 2:R2=0; ok=1; x=1;
