Executions for behaviour:
"0:R0=0 ; 0:R1=1 ; 0:R3=0 ; 1:R0=0 ; 1:R1=1 ; 1:R3=0 ; ok=1 ; x=1 ; y=1"
ARM SB+rfiar-addrrnas "RfiAR DpAddrdRRNa FreNaA RfiAR DpAddrdRRNa FreNaA" Cycle=RfiAR DpAddrdRRNa FreNaA RfiAR DpAddrdRRNa FreNaA Prefetch=0:x=F,0:y=T,1:y=F,1:x=T Com=Fr Fr Orig=RfiAR DpAddrdRRNa FreNaA RfiAR DpAddrdRRNa FreNaA { ok=1; %x0=x; %y0=y; %ok0=ok; %y1=y; %x1=x; %ok1=ok; } P0 | P1 ; MOV %T3,#1 | MOV %T3,#1 ; LDREX R0,[%x0] | LDREX R0,[%y1] ; STREX %T2,%T3,[%x0] | STREX %T2,%T3,[%y1] ; CMP %T2,#0 | CMP %T2,#0 ; BNE Fail0 | BNE Fail1 ; LDREX R1,[%x0] | LDREX R1,[%y1] ; EOR R2,R1,R1 | EOR R2,R1,R1 ; LDR R3,[R2,%y0] | LDR R3,[R2,%x1] ; B Exit0 | B Exit1 ; Fail0: | Fail1: ; MOV R4,#0 | MOV R4,#0 ; STR R4,[%ok0] | STR R4,[%ok1] ; Exit0: | Exit1: ; Observed 0:R0=0; 0:R1=1; 0:R3=0; 1:R0=0; 1:R1=1; 1:R3=0; ok=1; x=1; y=1;
