ARM LB+addrra+pora "DpAddrdWRA RfeAR PodRWRA RfeAR" Cycle=RfeAR PodRWRA RfeAR DpAddrdWRA Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpAddrdWRA RfeAR PodRWRA RfeAR { ok=1; %x0=x; %y0=y; %ok0=ok; %y1=y; %x1=x; %ok1=ok; } P0 | P1 ; LDREX R0,[%x0] | LDREX R0,[%y1] ; EOR R1,R0,R0 | MOV %T3,#1 ; ADD %T1,R1,%y0 | LDREX R1,[%x1] ; MOV %T3,#1 | STREX %T2,%T3,[%x1] ; LDREX R2,[%T1] | CMP %T2,#0 ; STREX %T2,%T3,[%T1] | BNE Fail1 ; CMP %T2,#0 | B Exit1 ; BNE Fail0 | Fail1: ; B Exit0 | MOV R2,#0 ; Fail0: | STR R2,[%ok1] ; MOV R3,#0 | Exit1: ; STR R3,[%ok0] | ; Exit0: | ; Observed 0:R0=1; 0:R2=0; 1:R0=1; 1:R1=0; ok=1; x=1; y=1;
