ARM WRC+dmb+addr-fri-rfinar-addrrna "Rfe DMBdRW Rfe DpAddrdR Fri RfiNaR DpAddrdRRNa Fre" Cycle=RfiNaR DpAddrdRRNa Fre Rfe DMBdRW Rfe DpAddrdR Fri Prefetch=1:x=F,1:y=W,2:y=F,2:x=T Com=Rf Rf Fr Orig=Rfe DMBdRW Rfe DpAddrdR Fri RfiNaR DpAddrdRRNa Fre { %x0=x; %x1=x; %y1=y; %y2=y; %z2=z; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%x1] | LDR R0,[%y2] ; STR R0,[%x0] | DMB | EOR R1,R0,R0 ; | MOV R1,#1 | LDR R2,[R1,%z2] ; | STR R1,[%y1] | MOV R3,#1 ; | | STR R3,[%z2] ; | | LDREX R4,[%z2] ; | | EOR R5,R4,R4 ; | | LDR R6,[R5,%x2] ; Observed 1:R0=1; 2:R0=1; 2:R2=0; 2:R4=1; 2:R6=0;
