ARM W+RWC+rfiar-datarna+addr+dmb "RfiAR DpDatadWRNa Rfe DpAddrdR Fre DMBdWR FreNaA" Cycle=RfiAR DpDatadWRNa Rfe DpAddrdR Fre DMBdWR FreNaA Prefetch=0:x=F,0:y=W,1:y=F,1:z=T,2:z=F,2:x=T Com=Rf Fr Fr Orig=RfiAR DpDatadWRNa Rfe DpAddrdR Fre DMBdWR FreNaA { ok=1; %x0=x; %y0=y; %ok0=ok; %y1=y; %z1=z; %z2=z; %x2=x; } P0 | P1 | P2 ; MOV %T3,#1 | LDR R0,[%y1] | MOV R0,#1 ; LDREX R0,[%x0] | EOR R1,R0,R0 | STR R0,[%z2] ; STREX %T2,%T3,[%x0] | LDR R2,[R1,%z1] | DMB ; CMP %T2,#0 | | LDR R1,[%x2] ; BNE Fail0 | | ; LDREX R1,[%x0] | | ; EOR R2,R1,R1 | | ; ADD R2,R2,#1 | | ; STR R2,[%y0] | | ; B Exit0 | | ; Fail0: | | ; MOV R3,#0 | | ; STR R3,[%ok0] | | ; Exit0: | | ; Observed 0:R0=0; 0:R1=1; 1:R0=1; 1:R2=0; 2:R1=0; ok=1; x=1;
