Test MP+dmb+fri-rfi-pos-addr-rfi
ARM MP+dmb+fri-rfi-pos-addr-rfi
"DMBdWW Rfe Fri Rfi PosRR DpAddrdW Rfi Fre"
Cycle=Rfi Fre DMBdWW Rfe Fri Rfi PosRR DpAddrdW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe Fri Rfi PosRR DpAddrdW Rfi Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0           | P1              ;
 MOV R0,#2    | LDR R0,[%y1]    ;
 STR R0,[%x0] | MOV R1,#2       ;
 DMB          | STR R1,[%y1]    ;
 MOV R1,#1    | LDR R2,[%y1]    ;
 STR R1,[%y0] | LDR R3,[%y1]    ;
              | EOR R4,R3,R3    ;
              | MOV R5,#1       ;
              | STR R5,[R4,%x1] ;
              | LDR R6,[%x1]    ;
Observed
    1:R0=1; 1:R2=2; 1:R3=2; 1:R6=1; x=2; y=2;
and 1:R0=1; 1:R2=2; 1:R3=2; 1:R6=2; x=2; y=2;
